shower install help
coastalcruiser
Hello, I just took my toilet out and though hull fittings.
The problem I have is what to use where the toilet sits, there was plywood but water got in so im planning to use fiberglass but cant find any thick enough to support the toilet.
Plan to provide drainage though the stringer so if water does get in at least it can escape.
Want to level the floor and provide a shower drain to a shower box/pump in the bilge, just not sure what to use to make the water drain to the right side. any ideas?
so far I have thought of bondo, with fiberglass layed over that and gelcoat.
oops!
Re: shower install help
check the latest post on the hull extension thread......same project.....different part.
cheers
oops
coastalcruiser
Hey Ooops nice progress on your swimstep!
thinking of layering glass on some wax paper and adding some ply for the toilet to sit on with the edges cut to 45, when its dry cut it to fit. then, glass in the corners. that will do the top
for the floor i think ill sand and bondo then sand it smooth with the drain in place and masking tape on it after all the glassing is done use bondo and sand smooth then brush on gelcoat.
oops!
forget the bondo bud......lordco has a short strand poly filler.....(waterproof).
it sands tough but it can be done. im using it right now on the final faring of the cap.
once you have the shape. you can gellcoat and sand as smooth as you want.
the wax paper works great.....it is all over in the next set of pics i will post
coastalcruiser
Hey thanks man, I knew there had to be somthing better
coastalcruiser
Re: shower install help update!
went to check out industrial plastics and paints, gos some unwaxed resin and some heavy mat, and layered 3 pcs on wax paper the saturated this cabinet ply, and put one more layer on top, now i have my toilet base.
Its just warm enough to kick
Tomorrow i have this idea!! cut mat /or cloth in thin strips and form it around doweling wrapped with wax paper to make inside corners.
I want to end up with smooth corners like this fancy head don't know how but I'm going to try!
Also going to get some of that shortsrand poly filler and level the floor
found a shower pump that will fit in my bilge just need to get a good price and need a drain that should go in before I start leveling.
coastalcruiser
Progress so far
Progress so far
Trimmed the ply for the toilet, its fitted in and ready to glass, sanded the floor and made a maple step to contain the water. Hard to see but the floor has one coat of glass around the perimeter and the drain hole is in (its out of sight) Floor has a dip so i got some 3M waterproof filler and next i'm going to fill the floor with the drain in and taper so water will hopefully drain....hopefully
A shower pump kit is $125 here on the island :eek: so i'm making one out of a plastic Tupperware box for $7.99 I like it because it has a flip tabs for access!
I have a rule pump and got a float switch and a bilge pump kit so I'm all set for about $50 bucks
coastalcruiser
Dumb idea, thought of new plan
coastalcruiser
redneck shower drain pump
coastalcruiser
Got some longhair poly filler to fill the hollow part, then used poly glazing putty to level out the floor. also plan to use it to prep for gelcoat everywhere I glassed,
Im sure gelcoat is the thing to use for the floor pan but not sure what to use for the walls, I was thinking of enamal paint.
coastalcruiser
Filled and sanded! going to gelcoat the bottom and use enamel paint for the rest
coastalcruiser
shower finished
shower finished
:) No more dust! no more respirator! Here is the finished project.:D
Just have a bit of touch up to do on the right there...
Mark42
Nice job! That looks like it will stay nice for a long time.
When you take a shower, and the water goes into the drain in the floor pan, where does it go from there?
Mark42
Oh, I get it. I thought the box was under the head. Now I realize its in the center of the boat . Nice setup. How well does the head work?
coastalcruiser
seems to work, poured some water in there over the weekend, havent taken a shower but my homemade pump works fine. My girlfriend likes it because its clean ;)
coastalcruiser
these mats from west marine should solve the drainage issue. and keep my pants dry
