The threads are stripping on the cheap/cheezy PVC drain in my shower and it is leaking around the brittle cheap rubber gasket. Silicone calking is only a temporary fix.
I'd like to replace it with a decent brass drain, but the only one Lowes sells, uses on the bottom, a rubber internal "compression" seal, that appears to simply slide over a 2" PVC drain pipe, verses some type of glued joint, normally used with PVC.
Is this a common design for a brass drain and can I assume that it should not leak for the rest of my life, or at least a few years longer than the lame pvc?.
