shudder & pulling right
reilly
My force 125 pulls hard right all the time. the skeg is slightly bent to the left is that the problem? also it shudders between 1000 and 2000 rpm. any help would be appreciated.
Oldsaltydog
Re: shudder & pulling right
Is your prop well mounted and in a good shape?
reilly
it is well mounted and has 3 small dings in the prop
Oldsaltydog
The shuddering could be caused by your prop being out of balance. For the pulling to the right problem you could look under SEARCH for some leads.
eurolarva
The bent skag cant be helping maters any. Most motors pull to the right because of the torque of the motor. Does your motor have a torque tab? Did this problem become worse after you bent the skeg? You should have a mechanic look at it. If the prop is damaged or the skeg is bent enough to cause the prop to worbal you run a chance of ruining the gears, clutch and prop shaft in your lower unit not to mention what kind of stress you are putting on the motor.
