shut off engines while in gear
torcano
I accidently shut off my engines (Mercruiser 4.3L I/O with Alpha I sterndrive) while in idle. I thought the gear was in neurtal. The boat coasted for about 60 seconds. I realized something was wrong I heard a a sound coming from the stern which was the propellers turning from the force of the water as the boat coasted to a stop while still in gear. Once I put it back in neutral the engines started right up and I was able to return to my marina with no apparent problem that I could detect. Could I have damaged anything in the sterndrive? Should I be checking anything? Dumb mistake on my part.
abj87
Re: shut off engines while in gear
clicking noise right? No worries its just the dog clutch overrunning. Didnt hurt a thing.
Uraijit
Banned
Yeah, it's designed to do that. You should be fine.
mthieme
No problem.
I had to do this with mine for four years before I finally got around to replacing the shift cable !!!
chiefalen
It's nothing, nothing. Your still good to go.
torcano
Definite clicking noise as described by abj87. Thanks for all your inputs.
