Re: Shutting down the motor?
Springbok.... You can do that as long as the engine has but one carburetor. When that carb rubs out of fuel, the engine simply stops running. Cuts down on the gas spillage in the trunk of your new BMW.<br /><br />However, when the engine has more than one carburetor, that practice should not be carried out. The reasoning not to do that is simply that the top carburetor will run out of fuel first, if for no other reason, gravity.<br /><br />This will result in having at least one aluminum piston running up and down a steel cylinder wall with improper or no lubrication. Really not a good idea.
