Sierra, Mallory, or OEM water pump?
GulfCoastNik
Hello,
I am a very guilty owner of a 2000 Ficht 225 that I have not maintained very well. I've owned it since 2004, and have just decided to get serious and maintain it like I should. The first step involves replacing the water pump , plugs, lubing it good, decarbing, etc. I bougth a Sierra impeller, but when I got the old housing off, the gaskets were shot, and the small O-ring that is THINK goes in between the top of the impeller and the pump housing/liner is shot. The aftermarket kits are a good $20 cheaper than OEM, but I don't know enough about them yet to know if I should stick with OEM or not.
Also, what type of gasket sealant do you guys use? The previous kit was installed with a yellow, slightly stiff/hard sealant.
:confused: Any opinions?
matt2002
Re: Sierra, Mallory, or OEM water pump?
stick with oem.use the sealer specified in the manual.replace the t stats too.
tashasdaddy
not maintaining a Ficht is the worst thing you can do. there have been some computer changes, for these motors, and the OEM service center can tell you if you need the upgrades. i like oem parts for critical parts. impeller, tstat, carb kits, fuel pumps.
Benny1963
i run sierra in one motor and brp in the other the only difference i see
is 20 bucks
