signal for a tack
piggy
Hooking a tack to a 1999 johnson. I understand the black wire is ground, the purple wire is hooked to switched 12 volt, blue is for back light and grey is for signal. The question I have is were is this hooked to on motor and would it be correct to set the dial on the back on tack on 3 pulse for a three cylinder motor. First time for this hook up for me so any help would be great. Thanks
piggy
Re: signal for a tack
Sorry forgot to add 1999 Johnson motor is a 25 H.P. don't if this makes a differance.
samo_ott
I had no idea what this thread was until I opened it up... But I guess I could have guessed... It's 'Tach' which is short for tachometer.
jay_merrill
LOL - I was gonna say "Ready About!" and suggest that the thread get moved to the sailing section!
tevans720
I beleave with Johnson motors the tach is set at 5P. Just hooked one up for my Johnson.
When you bought the tach it should have came with some directions which will tell you the settings. If it didn't and you wanna be 100% sure look it up on google you will find it. But I'm 99% sure it's 5P for Johnson motors.
Hope this helps.
Chris1956
Piggy, The Tach counts the number of pulses from the stator. The grey wire is therefore hooked up to one of the stator wires (Usually yellow)
