My engine has been repaired by a mechanic and it runs fine, it gets to it max speed when it's running, but then if I let it idling in neutral for a while, because I just want to float around, and i put it in (forward) gear again and I give full throttle, it runs just a little faster than idle, but then I go very slowly forward (if the wind is not blowing me backwards
). If I turn the engine off and then start again, the problem has usually gone. but off course I want an engine that gets to it full rpm after idling and not that I have to start it over and over.<br />Another thing that I find suspicious that I ALWAYS have to use the choke to start, even when it's on working temperature.
<br /><br />According to the manual there's no remote control available and not possible for this 5.5 HP, but does anyone have such a rich fantasy, that he or she can make up a way to make rhe clutch and steering remotely controlled
