silly question about a tri hull
brian3127
i know it would probably be cheaper to get the hull that you want instead of redoing one. but im just wondering. i was fixing a hole in my hull and while i was laying on the ground looking at the hole. i was wondeing if anybody has ever made a tri hull into a V hull and how hard would it be to do.
Bob_VT
Re: silly question about a tri hull
Were you working with chemicals :eek: ???????
I am not aware of that switch being done...... ;)
Bob_VT
How did the seacast come out? You are almost done aren't you?
brian3127
it came out good im done with it now just have to put the boat back together. hoping this weekend.
yes i was working with chemicles epoxy but i figured the work opps is doing a major project like that.. some one would have tried that
danond
Bob's comment was basically asking "dude are you high?" :)
Switching the hull type would be possible, very, very expensive, and nutty. People have done crazy things, though.
I'd suggest starting with the hull type you want vs. trying to change it.
brian3127
yeah i know what he was talking about i wasnt high. my mind is always thinking of things wierd like that. im not going to change the hull design i was wondering if anyone has done it before.
Bob_VT
I quoted your seat mounts in another thread a few minutes ago. Your doing good work....... stop staring at the hull and get it done :)
brian3127
thanks bob , beleive me im trying to get it done i have so much other stuff to do this year its not funny. i probably should have done the other stuff 1st but i figured after a hard week at work and the other stuff i have to do i can enjoy a saturday or a sunday in the boat on the lake.
Yacht Dr.
Hello m8..
welp..first off getting a modded V on your VW and make it structurally sound with the hull would be very extensive.. think stringers..bulkheads..transom mods..drain system..accessibility..inside/outside lams ( gutting the whole inside of the hull for lam access) ..etc .
No Problem .. just bring it on over with your pockets filled with cash. ( oh.. make sure they are the kakie kind with pockets down the legs too ;) ).
However..creative thinking like that could one day line your pockets with gold..
YD.
redfury
I think it would mostly depend on the hull you are starting out with. The hull on my boat is close to a V, but you'd have to take out the faux tunnel hull aspect of it to get a hull that would plane and handle properly.
I think that would be the biggest aspect to consider from an engineering standpoint. I think you'd have better luck turning a Tri hull into a Jon boat.
