csherrill2
- Aug 18, 2012
- 39
I have a 97 mercruiser 4.3L with a mercury alpha one gen 2 outdrive. heres my dilemma. I have changed the gear oil in my outdrive twice in a month, (new gear oil after a rebuild, then the second time was when I had to look for a water flow issue) Now I am going to assume I have everything correct NOW, and I dont want to add another 25 dollars of gear oil in my lower unit again unless I know its going to be right. Heres my question. CAN I run my engine for 2-3 minutes to verify that waterflow is appropriately going to where it needs to go without having gear oil in my outdrive? I WILL NOT be running it in gear, just long enough to verify that water is going through the block etc. I dont want to cause any harm to anything but I also do not want to throw away another 25 dollars worth of oil again. Thanks.
