Silverline19
- Jul 8, 2010
- 9
Well I Started with the rebuild on my 72 silverline. The weather finally started to cooperate. Last summer I removed the deck, floatation foam. Recently I took out the center stringer and cleaned out most of the fiber holding it in. Found a combination of a good chisel and flat bar works best for the large pieces followed by a belt sander to smooth it out. My plan is to replace and secure the center stringer first and work out out towards the sides evenly so I don't loose the integrity of the hull. The transom looked good and solid but as I got closer to the back of the boat and removed the tiedown hooks and engine mounts that the transom is pretty bad in places. So off to another adventure. I am cutting the removing the top of the boat just forward of the rear fairing. that way I can replace the transom ad put the rear faring back on with little trouble. My question is 1st: Is this the best course of action and 2nd is there any suggestions to re-attach the top two pieces together?
