Re: Simple/ dumb question
Get some 16 gauge wire. Marine grade tinned copper strand is best, but I've used automotive with good results. Get a good quality wire stripping and crimping tool, and some crimp-style terminal ends that will fit the posts on back of your switch. Also some terminals that fit your boat's fuse box, or if there's no fuse box, some ring terminals that fit the battery studs, some butt connectors, an inline fuse holder and 2-amp fuses.
One wire goes from battery positive to inline fuse holder (or fuse box) to toggle switch. Two wires go from the other toggle switch post, one to each light. Two wires go from the battery negative, one to each light. If using an inline fuse, put it within six inches of the battery.
If they are LEDs, the lights will have a negative and a positive connector; the wire from the switch has to connect to the positive, and the negative has to lead to the battery negative. If they're not LEDs, it doesn't matter which wire leads where.
