SS MAYFLOAT
- May 17, 2001
- 6,372
Several years ago at the dock, there was guys coming into the marina by boat late at night. They would run a hose down your gas fill and use an electric pump to get your gas. I tried the locking cap, but they have all the time they need to pry and chiesl it away.
I've come up with a simple solution. I've taken two blocks of oak 1x4x10 inches. I drilled a 3/8 inch hole thru both blocks at each end. I then got 2 stainless carriage bolts 6" long 3/8 dia. I run the bolts thru each end of the two boards and then used stainless wing nuts plus washers. This is basically like a clamp. I put my fill hose between the boards and tighten down the wing nuts smashing down the fill hose. I don't tighten it down all the way, just enough to keep a hose from being pushed thru. My bilge compartment is locked down, so there is no way they can get into it. I'm going to put it on when I leave the boat and then remove it when I return for the weekend.
At least this is the way I'm going to try to keep my precious liquid from being stolen this year. I can't see why it won't work.
