Single Battery hookup
mihop1455
I have a 2003 Stardeck. I disconnected the battery and brought it inside for the winter. I went to hook it up and have forgotten which wire goes where. I 'm ok with 2 major cables. But there are two other wires that need to be attached. Do they both go on positive ? Does one go on neg and if so which one ? With both on Pos, motor will not turn over nor will lift/ lower operation work . What am I missing ?
roscoe
What are these "extra" wires for?
What are the connected to?
Are they color coded?
What happens when you do not connect the extra wires?
Do any of the wires get hot when connected?
When you figure it out, make sure you label all the wires.
