05StingRay
- Aug 7, 2016
- 23
Good afternoon all
Struggling with an issue on my 05 4.3 MPI. Runs great when engine is running hard, the issue only comes when idling or running at RPMs under 2000. We will be putting along and get a single beep and immediate cut back on power, can then rev the engine back up and acts like nothing happened. Keep putting along and it will do it again but not at any regular interval. Get through the no wake zone that we were putting through and hammer down and no problem running at normal top speed or continuing across the water until we get back to the lower RPM.
Gauges all read fine for water temp and oil pressure. Checked oil level and it was fine, checked drive lube and it was good. Really confused as to what is causing my issue but look forward to any advice you may have!
