Re: Single engine outboard motor bracket
There was an ad I saw a few months ago where someone had a 22' Starcraft aluminum cuddy which originally had an OMC sterndrive. About a 1985 boat, if I recall.<br /><br />The seller had removed the engine and also the lower section of the sterndrive and replaced it with a 9.9 hp Evinrude outboard. Still used the sterndrive steering and tilt. Looked like a very simple, if strange, swap.<br />Think that a large vertical bolt attached the outboard to the upper sterndrive section.
