Railroader12
- Aug 1, 2018
- 46
I had a leaking trim ram on a 1999 90 mercury 2 stroke. Ordered the seal kit and tore it apart, everything is out, other than I'm stuck at the piston/rod.... I cant figure out how to remove the lower threaded section so I can replace the dust seal that seals the rod itself, which happens to be the ONLY seal/oring that actually needs replacing! I tried heat and penetrant to loosen things but am scared to put it in a vice or grips. Seems like those piston assemblies are far and few between if I destroy or gouge it too bad I'll be screwed.
Anyone??
Anyone??
