Sink Draning Issues
Limited-Time
Trap is new and clear to the wast line. Waste water plumbing is old, old iron piping. I fear its rusted closed. any suggestions short of tearing it out and replacing it.
rbh
Re: Sink Draning Issues
did you try snakeing what you could reach?
a70eliminator
A 25' hand snake (drum auger type) is a tool I couldn't be without, I have a wife 2 teenage daughters 3 showers and the drains clogged (little exaggerated).
It doesn't matter how clean that trap is if the restriction is downstream.
I would suggest a 15-25' hand drum auger, leave the trap in place and feed it in through the pop up or whaterver, run hot water as you work the snake.
My house was built in 1951 the drains are cast iron with leaded joints so i know where your comming from.
j_martin
Steel sewer piping will rust shut over time, or leak. Cast iron, or plastic won't. If it is steel, bite the bullet and replace it. Plastic isn't that hard to work with.
hope it helps
john
scipper77
I've been there too. I have this theory that when the inside of the pipes are jagged the hair just coats the pipe. In any event every time I would clear my drain it would be slow again a month later untill......
One day my upstairs shower clogged and when you ran the sink long enough rusty muck would back up out of the drain. I thought I was going to have to tear up a floor or ceiling to run a new drain for sure. As a last ditch effort I purchased a product that forces compressed gas in a can through the clogged drain. Because the sink and tub in the upstairs bathroom were attached to the same drain line and the clog was after they joined together I had to do the following. I filled the sink and tub to the overflow drains with the tub overflow clogged with a washcloth. I then with the help of my wife simultaneousely opened the sink and tub drains, held the sink drains plugged with two rags (wife did this) and blasted the compressed gas out od the can down the tub drain.
Because all of the drain lines were filled with water and the drains were all plugged the compressed gas blasted the constriction down the drain. Now I had tried drano, plunging and even had a plumber come in and run a snake in the past but this technique was the only thing that ever lasted as a fix. And let me tell you that the drain ran better than I had ever seen before after that.
I'm guessing that there was a restriction of rust in the pipes that was catching the hair, and the pressure broke the rust free along with the hair but I really have no idea what was going on.
I've also heard of people opening up the trap in the basement and running the snake backwords, up the stack.
Tubingluvr
Another good inexpensive trick to try is a tool they make that fits on the end of a garden hose,it is rubber and expands to seal off the pipe and shoots a jet to break loose whatever is clogging the pipe.
Another thing that is well worth the expense is having a plumbing company come and camera out the pipe, which will tell you exactly where the problem is and what is causing it.
It is basically like sending a snake down the pipe with a video camera on the end of it.
Limited-Time
Thanks for the suggestions. I've tried the compressed air over water, no luck. My next step will be the snake. i just wasn't sure if it would knock the rust clogs out. I may give the water blaster a try first.
