tomatolord
- Oct 1, 2004
- 548
NFL - which is what i wanted<br /><br />nhl - nascar - nba - mlb <br /><br />as far as stations they did appear to have about the<br />same<br /><br />I guess you could check if they have marin versions, but they both have boom box versions, where you can move the receiver from the boom box to the car.<br /><br />DO NOT go for the wireless version. This one transmits the signal to the radio via an unused fm station - if you travel I can gaurantee you that the station you transmit to will be in use and you will get only static.<br /><br />its an extra 20$ for the wire line connector to connect it directly to your existing radio.<br /><br />OR<br /><br />You can just replace your entire radio with a satellite version.<br /><br />tomatolord
