Sitting Low?
egleas84
Is my Stingray sitting low to you guys? I've only had this boat out 3 times and my last one was a lot higher up. I've had it tilted all the way up in the garage and there isn't water coming out. Maybe I'm just paranoid; I've had issues with hole shot bog but I think I've got it narrowed to dirty carb jets and the wrong prop pitch.
'78 Crusader
Re: Sitting Low?
Looks fine to me as well. Maybe you're carrying more fuel this time than you did last time.
Your trees need some leaves bro....that's depressing. Lol.
egleas84
Re: Sitting Low?
All the trees around Wisconsin have the depressing look in April. Should be nicer next month.
I'm hauling 5 more gallons than my last boat; not to metion the heavier Mercruiser. I was starting to worry my flotation foam maybe soaked... but if it's not sitting 'low' in the water then it probably isn't or at least not badly.
E
LippCJ7
Re: Sitting Low?
I think your just in lite water, as the summer gets closer the water should get heavier and your boat will ride higher in the water......
Dude at least your on the water!!:D
egleas84
Re: Sitting Low?
NO WAY!!!! You have to be pranking me (looks around for cameras)...... then again if it is true that means that I will also plane better when its warmer!
Darnit; I'm an IT guy not a physicist!
LippCJ7
Re: Sitting Low?
LOL Sorry I'm in a good mood, yes I am pranking you!
ajgraz
Re: Sitting Low?
I was gonna say the OP's boat looked fine, but after seeing woosterken's boat I'm not so sure. Of course each boat's different...
To the OP, do you have an old scumline on the side that you can compare against the current draft?
Alumarine
Re: Sitting Low?
They're different boats - you can't compare them.
egleas84
Re: Sitting Low?
Yeah. A trihull versus a deep V isn't too good of a comparison (no offense). if it was the same stingray i'd be worried!
No scum lines; I keep her clean!
