Re: size drill & tap for hellicoil
reeldutch,I believe the broken bolts were 1/4 x 20 .What you need to do is order a Helicoil kit.It comes with a drill,special tap,thread inserts and a tool to install the inserts.In the future you have the kit,and just buy more inserts. <br /><br />I think you can STILL order them from Johnny-Rude,but a local bearing supply house can do it also.<br /><br />In some cases,because of the over sized drill,for the over sized tap,there isn't enough material there.But I think you'll be OK on this application.<br /><br />DHP
