size of 78 johnson 140 spark plug hole??
Ranger 330V
I think it is 14mm correct me if I'm wrong...I found an adjustable piston stop from comp cams for 12 bucks and thats new....much cheaper than the BRP unit...what do you guys think?? Item number: 140153202838 on ebay..check it out...may be a cheap way to get a good quality piston stop for our engines. thanks!
F_R
Re: size of 78 johnson 140 spark plug hole??
The hole is 14MM. That should work
Ranger 330V
thanks alot..looked like a good simple and "cheap" tool...less than 20 bucks with shipping...thanks again!
rusty178
I know that I am a little late but I just joined up..A cheaper piston stop tool is a peice of rope stuffed into the combustion chamber.I used that stupid method for years on lawn equipment..
