Bama Hound
- Jul 30, 2012
- 47
I had to replace a water cooled regulator rectifier this year. I had just replaced last year. I am concerned as I believe this is pre-mature failure and am trying to look at things on this motor with a jaundiced eye. I am sure some other knucklehead other than myself has been on this motor first. My PSI gauge on the dash reads about 2psi at idle and 7 to 8 lbs. at fast idle. I have replaced the water pump and housing. The old pump and housing were not that bad. Another forum member got me looking at the plumbing on the tell tale. Line has been "T-ed" with one leg going to the stream and the other leg going to the dash gauge. Question is I have a 3/16" pee stream, is this a big water leak causing the water cooled rectifier to overheat? Do I need to reduce this?
