Skeg guard for Volvo Penta SX-A
Glastron185
Hello All, new member here.
Does anyone know where I can find a skeg guard for a Volvo penta SX-A? I bought one and installed it but it didn't fit right. I made the mistake of drilling the holes even after realizing that it didn't fit right thinking it's just a skeg. What a dumb mistake on my part. After realizing how dumb of a mistake I made, I decided to call the marine shop to see if they could fill in the hole and fix the skeg and was told that they could do it for $145 and make it look like it never happened. My only concern is heat transfer.
I figured since I drilled the hole why not talk to my local machine shop. After going back and forth and talking to my local machine shop and explaining what I needed done, I was told that they could make a skeg guard out of stainless steel. I showed them the skeg guard that I had and was told that they could make one similar but made to fit and possibly form around the skeg. The only issue is that they want me to buy a minimum of 20 skeg guards and also charge me for design and some other fees related to configuration of their machines. If I knew that others might be interested then I might consider having them made, but would rather just buy one from a vendor if anyone knows a skeg guard that fits the SX-A.
Dave-R
Have the people who quoted the 145$ do it. They will leave the oil in the drive, and the heat will be okay. I had my prop shop fix a bad one for 250$ and it turned out great. The skeg guards just lets everybody else know you are a screw up. And you will always wish you fixed it. By the way I didn't do it, I bought it that way. Dave-R
Yegboats
Skeggard, and SkegGuard are different companies that offer similar products. Panther also offers stainless skeg boots.
Skeggard brand sells sx drive 1995-2006 item# 99022 sx drives from 2007-current item# 99020
SkegGuard sx drive 1995-2006 item#27221 sx drives from 2007-current item#27191
Panther skeg protector 1995-2006 item#35ss665 sx drives from 2007-current item#35ss655
I'm sure you can find all of these on iboats
Glastron185
Yeah I plan on having them do it and will ask if they will leave the oil while doing it. I am for sure a screw up, I went through two props on the same day I chipped the skeg :) I'm not a good boater and probably should not be allowed to own a boat.
Glastron185
The panther SX skeg protector does not fit right on the SX-A as there are different versions of the SX outdrive. That's the one that I installed. I will look into skeggard and skeg guard.
I added an image from the panther skeg guard I installed.
spoilsofwar
You need Skeggard part number 99020. This will fit the SX-A and DPS-A drives. The one you have, which does not fit, is intended for SX-M drives.
Glastron185
Ok great thank you. I will buy one this weekend. Now I will have to fill in the holes that I already drilled. Thanks again
spoilsofwar
What it looks like installed:
Glastron185
Is your skeg shaped like mine? I attached an image. The reason why my skeg is green is because i primed it. I ordered the volvo penta paint so that i can paint it.
