Ski prop for 15' tri-hull
Got a '73 Pacer 15 foot fiberglass tri-hull with 65 horse Evinrude outboard model 65373r.. Motor freshly rebuilt but has slightly mangled prop. This prop seems to work okay for cruising but has slight vibration from the bent blade (got it close as I could)..
Looking for a good prop that will work to get a skier out of the water.. the boat doesn't weigh much, around 500-600# minus the motor and people. Not looking for absolute optimal performance, just need somewhere to start. Motor is running good and I think it tops out around 5000 rpm.
The whole rig is old so I'm not expecting too much ;)
steelespike
Re: Ski prop for 15' tri-hull
To do it right we need the present prop size(usually found on the barrel)
-- X -- diameter X pitch. Max rpm.and speed would be a plus.
These specs are to assure best performance and the health of your motor.
