bob johnson
- Feb 25, 2009
- 4,306
I picked this 1988 70 hp up last year about this time..one thing led to another and i eventually dissasembled it...not wanting to be so close to repairing or replacing something while I had it THAT FAR apart and not take care of it...which led to me TOTALY taking it apart!!
what i found was what looks like a FRESH rebuild with .040" over pistons.
BUT it appears that something let go and was smashed between the head and piston on the bottom cylinder...
but then they just replaced what ever broke and reassembled the motor!
i checked and ALL needle bearings are accounted for and the rings looked brand new.. the pins that keep the rings from rotating are in place.. the crank bearings are all in their races...
the pistons had ZERO carburization...super super clean...same for the rods...
with the exception of the hammering top and a few marks ON THE SIDE of the bottom piston..
I have had the block boiled and honed...he took out less than .0005"!!!
the block measure right for a .040 over bore..the pistons are marked .040.. and measure right.. have no skirt wear
here is the damage
i have since fly cut the top of the head .005" to clean it up!
here is the block post hone..just a few small places that stayed dark, i told him to just give me a surface to set the rings( in case i use brand new ones)
this picture shows just how the piston looked when it came out of the motor..seems pretty dang clean!!!
here is a pix of the side of the suspect piston
here is a picture of the slight drag mark from a piece of debris on the side of the piston above the ring grooves..which is y main question for this thread
will these slight grooves on the SIDE of the piston cause me problems, If i just reassemble this motor?
I will probably sell this motor, because since it bought it and took it apart i have aquired other motors to use for its intended purpose.
I have no notion to defraud anyone, buit i want to keep my costs of rebuilding this motor down!!!. it is tottally cleaned and painted..and ready for reasembly if I can come to grips with this piston issue.
I mean i took EVERY bolt off this thing and sand blasted every housing part and primed with antifouling primer and painted with Evinrude blue!!
I would add that the compression numbers were 115 120 and 120 when i bought the motor...
bob
here is the damage
bob
