spdracr39
- Aug 30, 2010
- 1,238
What are reasonable slip numbers for 3 blade aluminum vs stainless? Also if a 4 or 5 blade reduce slip why don't they make you go faster if you are turning the same rpm? Just trying to get a better understanding of how this works. according to my calculations I am getting about 16% slip with an average load ( three large adults plus gear and fuel) using my solas rubex three blade alum 14x19 and that seems high to me but maybe normal I just don't know. If I go to my 14x21 three blade solas new saturn stainless ( which is too much prop for my boat ) I get only 11% slip and go faster but can't get the rpm's up.
Here are my numbers:
14x19 alum 3 blade solas rubex
rpm 4200
gear ratio 1.47
speed 44mph gps
slip 11%
hole shot is good
14x21 3 stainless 3 blade solas new saturn
rpm 4000
gear ratio 1.47
speed 48 mph gps
slip 11%
I was thinking about maybe a 17p 4 blade stainless (undecided on brand) or a three blade stainless enertia 19p
The dealer recommended a 17p high 5. I don't really want to lose any more top speed than necessary but want to get a better pull for the kneeboard and tubing.
rpm 4200
gear ratio 1.47
speed 44mph gps
slip 11%
hole shot is good
rpm 4000
gear ratio 1.47
speed 48 mph gps
slip 11%
