Slow Boat or normal
Private Nemo
Hi, I have a 1985 Formula 28pc with twin Merc 260's. Last weekend was my first time out with the boat. Enjoy it very much. But, I was disappointed with the speed of the boat. At full throttle I was running at 3500 rpms and 34 mph.
Does that sound right , I thought it was a little slow.
Drew
Bob_VT
Re: Slow Boat or normal
yup too slow...... :(
Your motors do not sound like they are reaching their peak and optimum rpms. You should be seeing 4400-4800 rpms at WOT
You have some troubleshooting to do.
Private Nemo
Engines seem to run perfect. New carbs and complete tune up. I am leaning towards wrong props. Anybody have any idea what would be the best props for this boat ?
Drew
cr2k
Ones that will will run at max RPM at WOT with boat loaded as usually used.
spoilsofwar
Drew
What is the pitch of the props you have on now?
Augoose
From another article....
Think of a propeller as you would a car's axle ratio. The lower the ratio, the more pulling power from a standstill. The same is true with a prop. The lower the pitch, the better your hole-shot. However, this comes at a price: top speed.The lower pitch makes the engine reach maximum rpm at slower speeds.
Conversely, a higher pitch will deliver greater top speeds, but slower acceleration. Be aware that lower-horsepower engines can bog down if fitted with a propeller with too high a pitch and diameter, and that can wear heavily on internal engine parts.
If you're changing pitch on a recreational boat, remember that each inch of pitch is worth about 200 rpm.Lowering the pitch will increase rpm and vice versa. For example, going from a 23 pitch to a 21 pitch will increase engine rpm by about 400 revolutions.
Private Nemo
Hi , Thanks for the replys. This is my first season with the boat, so I am working out the bugs. It came with stainless steel props, I assume they were right for the boat, oops. I have know idea what size they are , didnt check
. So now I am trying to find out what was the original prop on this boat , not an easy task.
