slow boat
pdante62
I have a 1974 50hp envinrude on a 15 foot 830 pound bass boat. It only runs 15-18mph. please help
F_R
Re: slow boat
Assuming the boat isn't full of water, it is the same old story. It isn't running on both cylilders. Check spark, compression and carburetor. In that order. But don't ignore the simplest thing: Could just be a bad spark plug.
pdante62
Re: slow boat
ok I replaced the plugs fire system, both cylider are pushing about 124 psi, i aslo clean the carbs the boat is dry and flatation flaom is dry as well i worry about the prop which is a 13 3/8 17
Texasmark
Re: slow boat
Might try a decarb.
Tach data would be helpful.
Is the 850 just the boat, or total weight with occupants, fuel and all?
What does the engine sound like when you punch out of the hole? Does it sound good and strong, or wimpy and misfiring? I know your stated speed is just on plane, but does the engine sound like it's lugging at WOT or is it singing.......helps in attempting to determine rpm's.
How long does it take to go from standing stop to your max speed?
What kind of hull does your boat have...shallow semi-V, deep V, trihull, pad?
What condition is it in....clean, barnacles, slime?
Mark
pdante62
Re: slow boat
The 850 is without poeple, The motor sound great but idles a little fast and rough the boat does not plane and takes about a 1/4 mile to reach about 15 mph as for the boat it is very clean and has been waxed on the bottom. shallow hull ... what do you mean by a decarb
russ
pdante62
Re: how fast shuold my boat go?
I have a 15 foot 850 bass boat with an 50 hp envinrude on it, how fast should it run, will it plane?
