Any suggestions on a very slow leak in a automobile tire? Checked the valve, its ok. Would anyone recommend injecting the sealant with these fix a flat aerosol containers?
Howdy, Jess.<br /><br />I would recommend finding where it is leaking and fix it. You don't say what you have for a car, or wheels, but too often a slow leak is at the bead on the rim.<br /><br />Good luck.
I have to agree. Fix a flat is a temp solution at best. Personally I take my tires to the shop and let them plug or patch unless it is at the valve stem or beat then they fix that too. It is cheap and lasts.
