Slow loss of trailer hydraulic fluid
BULLWARKS
I have a single axle LoadRite trailer with surge brakes. I'm slowly loosing hydraulic fluid. I don't see ant sign of it where I park. any ideas?
Wheel cylinders would be my first thought. If the line is run thru the frame, a rusty line in the frame is second thought
alldodge
+1 agree with wheel cylinder. It leaks a little and the brake shoes are soaking up the fluid. Once they get saturated you will see them drip.
NHGuy
inspect the master, lines and wheel cyls. If you can't see it on the outside it's the wheel cylinder in the drum,
BULLWARKS
Thanks for the posts. I'm bringing it to a certified LoadRite mechanic. Ill suggest he check the cyls
