Ihave a DT65 horse suzuki and it is under powered when you go to take of i thought it was the prop so i changed it.it did'nt work. It seems that the rpm's are'nt high enough. But when you are going for alittle bit it will get up and go.could i still have the wrong prop. It is a 15 pitch 11" diameter.the boat is a 1978 lund 16'. Motor is a 79 . cleaned the carbs set the air screws so it runs clean but no hole.
