Slow to get on plane
Brandon15
3 vs 4 blade
I have a 17 1/2 foot regal open bow holds 8 people and has a mercruiser 3.0 which I think is under powered but I have a 19p on there now and would get on plane with 7 people but not really want to and now I bent the prop on rocks and looking for a new prop, should I try to find the same one or try a 4 blade with a 17p and hopefully get on plane fast with a boat full of people ???
Brandon15
I have a 98 regal bow rider 17’5 with mercruiser 3.0 boat holds 8 people but won’t get on plane have a aluminum 3 blade 19p on and played around with a few other props in aluminum and ss up to 21p and nothing really done good should I order a 4 blade and see how it works I need something to get out the hole quick and pull a wakeboard
Rick Stephens
The higher the pitch prop, the lower the motor RPM and power out of the hole. I ran a 15 inch 4 blade or a 17 inch 3 blade on my 17 footer when it had a somewhat tired 3.0L in it.
If you go out by yourself with the 19" prop, at wide open throttle (WOT) what max RPM do you get from the motor?
alldodge
What is your WOT throttle rpm with full load of folks and gear?
Brandon15
I’m sorry my tach don’t work so I really don’t know what the rpms are doing
alldodge
Need to get a hand held and see what the motor is doing
ALso notice your other thread where Rick has responded
Leardriver
A four blade prop gives you more blade surface area to help get big horsepower to slip less. You have the opposite of big horsepower:D A three blade is just fine.
Rick Stephens
IMHO, get it fixed or risk buying a motor. Boat motors run at 100% load 100% of the time. If propped too high you are constant lugging which will damage a motor quickly.
You cannot prop a boat without knowing RPMs, and you won't get it right without also knowing GPS speed - your cell phone can download and run an app to tell you GPS speed.
ahicks
A 17.5' boat with 7 people aboard sounds like an accident looking for a place to happen. The kind of boat you read about in Coast Guard reports.
nola mike
Also need to know if this is a problem with the engine. If this is new to you, you need to check compression, make sure the hull isn't waterlogged, timing, etc
JASinIL2006
You can get a Tiny Tach for about $50 and similar less-known brands for as little as $20. That would let you get RPM at least.
Is this a new-to-you boat? I would wonder if any boat that size with a 3.0 would get on plane quickly when loaded up with people and gear.
Brandon15
I will have to look into getting a tach and what rpms do I want to be turning ?? The boat is somewhat new to me and it does get on plane decent and I’ve had 6 people in the boat and pulling a wakeboard, (small lake with no public boat ramp so no traffic or anything) But the prop I have on there got bent and looking to see if I should change the pitch or blades to try and help out some or just get the same thing I had, I’m not sure the diameter of that one but the prop has 48 78120 a40 19p stamped on it.
Brandon15
Thanks to the people with advice and I would like to know the problem with a 17’5 boat with 7 people aboard ? The boat is rated at 8 and most of the time is spent on a small lake with no public access so usually the only boat out there ???
WesNewell
Mercury prop selector suggest a 21P prop at 41 mph with a max load of 4000#, so if you're having problems getting on plane with a 19P prop, you've got other problems. Really big ones if that's an alpha 2.40 GR.
Ayuh,...... 4400/ 4800 rpms, without the extra 5 people in it,..... closer to 4800 the better,....
Brandon15
Does anyone know what diameter prop this is ? 48 78120 a40 19p
achris
More fish than mountain goat
It's 14", but the diameter is not the main concern. Get that pitch down! 19" with that engine in that boat with 8 people? You're going to kill that engine. I'd prop you at 15" (pitch) as the start point.
Chris....
Brandon15
I don’t think I have other problems Becouse I can get on plane with 7 people and even pull a wakeboard with 6 in the boat
