Sluggish when accelerating with some backfire
Scrap1
1996 3.0L/ LX mercruiser. Sluggish when accelerating from idle or a stop, eventually backfiring. However, once it gets to about 3000 rpm it takes off. Rebuilt the carb, no change.
GA_Boater
Welcome aboard.
Did you adjust the idle screw (s)? Is the accelerator pump squirting?
Scrap1
I believe you’re asking about the idle mixture screw, it’s 1 3/4 turn out. Not sure how to check that the accelerator pump is squirting?
nola mike
Look down the barrel of the carb and have someone push the throttle (engine off is fine). Should see 2 streams squirting...
GA_Boater
Or pop the cable off and move the linkage if you have no help.
Did you fine tune the mixture screws?
