Ok gentleman I just bought a 1997 240 horizon with the fuel injected 454 and a volvo penta sx corbra with a 1.43 ratio.. I live at 6000' above sea level . The boat came from about 600' above sea level .. I put a four blade prop 17 pitch and the boat seems to do pretty good at the begging of the day.. I think it could be better however.. But the problem is that after awhile out on the lake doing some skiing and just sitting there. It almost will not plain... Takes awhile... I have moved people to the front etc .. I also lose about 500 to 1000 rpm at take off. Seems like motor is struggling... and with a 454 i dont think it should be.. Once we get cruising it seems to be ok but still not right.... when I pull the drain plug there is only about 4-5 gallons that comes out probably less... So I don't think that it is a extra water in the bilge problem.. But would cause the change from the begging of the day to the end of the day... Thinking of going to a 15 pitch prop.. but not sure if I shouldnt be looking into motor issues or outdrive ????
