Small crack
jlinton
I have a fiberglass hull that is showing some signs of wear. The most significant issue I have is a small crack that has opened up on the transom. I should have a picture, but don't. It is not actually the transom cracking but runs along, parallel to the transom right on the space for the outboard. Sorry I don't know the correct terminology to describe this more accurately. Basically I am after thee best product to try and seal this crack up. let me know if you guys have a particular favorite.
cheers
Woodonglass
Re: Small crack
Welcome to iBoats!
If your transom is cracking it is probably due to a weakened inner core and you need to investigate further. A quick patch is NOT going to solve the issue. Do a search here on the forum for Bad Transom etc.. and you will see what I am talking about. My signature line has a link on how to post pics. We really need to see what you're dealing with if you want us to be able to properly diagnose the issue.
Yacht Dr.
Re: Small crack
Yes..you should .. for correct information ..
Or you can just uncap it..replace the deck/trans/stringers and complete resto without them :) ..
YD.
