On a K car there is a small short. With ohm meter wire on 15V and other on 150ma the needle reads 10 when I bridge the -battery pole and the -cable unattached to the pole. Touch the elec. door locks and the needle goes up to 13. The only time the meter drops to 0 is if I unclip the red wire that goes to the + of the battery. Is that 10 volt discharge or is it 100ma? I removed all fuses and still had the discharge.
