ehenry
- Jan 6, 2002
- 2,393
I have a Generac 10kw stand by unit on my house. It is powered by a 22 horse Briggs & Stratton Vangaurd OHV engine. Yesterday the electricity went out and the unit came on as normal. After it had run for an hour or so I noticed it was sounding like it was under a really heavy load. I knew it wasn't that much of a load on the unit because we didn't have that much stuff on in the house. <br /><br />I went out and pulled the side cover off the little house that the unit is in and noticed that there was oil dripping from the air cleaner. When I pulled the air cleaner cover off if was almost half full of engine oil. The unit is made for extended run times and has an oil reservoir tank on it in addition to the normal crankcase oil. I powered the unit down immediately and checked the oil and it was WAY over full. Anybody got any idea why this unit would all of a sudden suck most of the oil from the oil tank into the crankcase until it puked it out the air cleaner??? Thanks in advance.
