bowbender6
- Jun 28, 2021
- 2
First post, been reading for a while. I have a 1973 Starcraft Islander with a rotten transom so I am tearing everything apart and going over things. I believe it is a Pre Alpha outdrive (no gimbal trim sensor, just trim limit at the top of gimbal Ring). I never noticed when driving the boat but there is a small amount of play between the splined shaft and the gimbal ring. The splined shaft is split and a plug goes up through the bottom of the shaft. Is that what is used to take out the play. I tightened it up a little but didn't want to go to far until I figured out if this plug opened up the split split shaft and tightened thigs up. I have several manuals and diagrams but hey weren't real clear on this matter
Thanks
Thanks
