I found a shop that will let me try a 26p laser 2 prop on my boat but the problem is that it is a small tube propeller... The back of the property is smaller in diameter than a normal prop and doesn't have the lip to fit in my outdrive and make a smothered transition to the property of instead there will be a vertical gap between the property and out drive.
Will this be a problem?
