imported_Blueskies
- Jan 21, 2007
- 1
Just bought a 2001 boat with twin 200's and the three guage Smart Craft system. I'm new to Mercs and still trying to learn their habits.
Every time I turn the batt switches on and start the engines I get a "Sensor Fault" msg on the port tach which then flashes to "Limp home Throttle" If I press the (mode) key the msg clears. The throttle response is normal and all temps and pressures read normal as you scroll thru with the "mode" key. The msg does not appear on any subsequent starts until I turn the batt switch off again. I have read thru the manual and cannot find this particular code in the Info or Troubleshooting section -
Is there an internal battery in the guages that needs to be replaced periodically??
Many thanks for your help.
