Re: Smart Tabs SX on 1989 Bayliner Capri OMC 2.3L 4cyl
For some reason it wouldn't take my text the first time and it won't let me edit my post so here is what was supposed to be the OP:
Hey everyone, my name is Dustin and this is my first post on the forums. LOVE the community here! I recently purchased my first boat, which is a (title says 16.5ft) Bayliner Capri w/ the 2.3L 4cyl TKO Cobra motor that turns ~128hp. The boat wasn't in bad shape when I purchased it about a month ago. The upholstery was re-done about 2 years ago and there are a few scratches and some fading on the outside of the boat but that is to be expected for it's age. I had the motor worked over and tuned up after having some trouble with it starting. The mechanic did a fuel system check up & service, oil change & filter, carb diagnosis, repair & tune, & diagnosed and changed a bad coil. My total parts replaced were the ignition coil, 1 point, condensor, rotor, dist cap, all spark plugs, 1 of the plug wires, choke coil, fuel filter, in carb fuel filter, oil & filter.
Do you think there is anything else I should check and replace or any other maintenance or updates you would recommend?
Now, the real reason I am here... I had recently replaced the prop on this boat because one of the blades had a pretty good bend and there were quite a few dings on the other two. The prop that was on the boat when I purchased it was a 13 3/4 x 13 and when I talked to a prop dealer he recommended that I install a 13 x 19 instead to preserve the longevity of my boat's motor. Apparently, that prop would be working my motor too hard and keeping it at too high of RPMs. Before installing the new prop, I was turning about 4500-4800 RPM at almost WOT. Now, I'm lucky to hit 3,500 trimmed all the way up with the hydrofoils right on top of the water. My hole shot had diminished and I'm staring at the clouds for a good 10 seconds before I hit plane. I have done some research and I see there are a TON of great recommendations for the Smart Tabs on a smaller boat like mine; however, I am having a little trouble with installation. I know that I am supposed to mount the actuator flat to the same surface but I'm falling about 3 inches short of being able to do so as I have a big curve in the way. I have attached pictures for reference below. Is there anyone who has a boat similar to mine that has any suggestions?
Thanks!
