Re: Smart tabs
Cool it;<br /><br />Top speed should increase with Smart Tabs, and if it does not it simply means that the pressure needs to be adjusted. As for side to side stability It should be compared to the suspension system on you car. Don S is recommending helm controled tabs as these will give you maximum ability to control port to starboard listing. This is most usefull when the boat is wide, or you are in major swells, or have severe balance issues.<br /><br />However; the single best advantage (performance) is not only easier planing, but the fact that Smart Tabs are always active and adjusting to the conditions. The imrpovement in the ride and handling is un-matched on smaller boats.
