Oh I’m not totally sure. Mine is on a Mercruiser and not an outboard, but we’re you’re old gauges smart craft ?
i do know that you probably have a communal port in the loom somewhere. Also that there is two fitting options.
I’d its anything like mine...you can plug them all in directly at the engine or at the ports interface under the dash (that will come from the engine), depending on the set up.
