Re: Smell of petrol in oil
Considering the performance aspects, you may have a carb issue. I think it's unlikely to be related to your fuel pump as it should be electric. It could also be entirely a condensation issue, both in your oil and in your distributor cap. If you're misfiring consistently, it's entirely possible to wash down a few cylinders and get a gas smell in your oil as a result. If you haven't changed out your cap and rotor in the last 2 years, change them. Otherwise, take the cap off as see what you've got in there, clean it up, dry it out, and wipe it out with your favorite moisture dissipator and see what you get.
