Smoke from Ignition Circuit Breaker
drjbarnes
Recently started my port engine and smoke began coming out of the ignition switch and circuit breaker. Breaker was hot so I replaced it with my spare and it immediately did the same thing. Called BoatUS and had them tow me back to the marina. Any ideas where I start to troubleshoot this?
Boat is a 1988 Sea Ray 340 Sundancer w/ twin 454's
alldodge
How long have you had the boat?
There are fuses in several locations and there should never be smoking from hot wires unless the fuse was replaced with a higher amp type. Your ignition fuse should be no larger then 20 amp
drjbarnes
Thank you this makes perfect sense. I will recheck the fuses.
