Smoked Tach
Maximerc
Last week I was at the lake, battery was down. I carry a spare with me, I unhooked the old battery and hooked up the new one. Started the engine .. good so far .. then with the engine running ( so I could charge up the old battery ) swapped leads. to the old battery. Well I can see thats not a good thing. I believe that I saved the rectifier but my new tachometer is smoked. Should have stayed on the new battery.
Moody Blue
Re: Smoked Tach
Generally not a good idea to swap anything while powered.
On the older Mercs, the switchbox ($$$) could be destroyed if you run the motor without a battery, even for a brief moment.
Chris1956
Re: Smoked Tach
Disconnecting the battery leads will almost always smoke the OEM rectifier as well.
