Smokey Yam
greenbeemabrian
hI
I`ve got an `86 f9.9AE Yamaha 4 stroke dual thrust. Recently on start up it smokes quite a bit and sometimes will not rev above 1800 rpm. If left to idle for 5 minutes or so, stops smoking and cruises without problems all day.:confused: No noticeable loss in oil level. Any ideas?
Yamajoe
Re: Smokey Yam
Before you come into port on the way home, make sure you have run the motor at WOT to burn out, check you oil levels.
rodbolt
Re: Smokey Yam
also try trimming/tilting the engine up when done.
if the clyinder bores spark plug end is below horizontal oil can run past the rings and collect in the combustion chambers.
its a simple fact of life on a 4 stroke engine.
so try storing it with the cylinders tilted so oil has to run back into the crankcase and not towards the spark plugs.
Yamajoe
Re: Smokey Yam
flat out, full steam, bust a gut, full throttle, lol, WOT is wide open throttle : )
