checkin the trim-tilt fluid level on my 2001 yamaha f115 tlrx ser# 68v l303984 s. raised the engine with the cowl switch and the black ground wire that runs from inside the mid section to the<br />lower mounting bolt started gettin hot and smoking. i had noticed before that the covering(insulation?)on the wire looked like it had been hot before. i had never seen it smoke before, and everything seems to operate ok. now that i've seen it smoke i dont want to run it. the wire connects (ends) with a connector to the lower mounting bolt and feeds down into the what i think is called the midsection. there is also another black wire and a small diameter rubber tube feeding into the same place. the burnt wire is on the starboard side of the engine. can anyone out there tell me what that ground wire grounds, and what could cause this situation, and the first few places one might look for the cause? as alway, thanks in advance, and thanks for the help you have given me in the past...Bill
