Re: smoking
Steve, I have a 1999, 90 HP Johnson with the same symptoms. I was told it was the oil left in the carb and system after setting idle for a period of time. I was told to disconnect and do away with the automatic oil system. Start with a full tank of fuel and add the correct amount of oil directly to the fuel tank as you would normally premix fuel and oil. I was also told I would not believe how much easy the motor starts. I have not had a chance to do this but it sounds practical. I would also like to hear from others on this idea.
Pete
